Activity Forums VEGAS Pro Using AVCHD and MP4 files while editing (GoPro and Sony Camera)
  • Using AVCHD and MP4 files while editing (GoPro and Sony Camera)
    Posted by Michael Bayley on January 22, 2012 at 1:24 am
    Hi guys,
    I am having a bit of trouble trying to use Sony AVCHD footage and GoPro MP4 footage in my edits. When I render the video in 720p there is horizontal “lines” in the AVCHD footage.
    Watch this video, I use a combination of the both throughout the video.
    Snow Valley Opening Day 2011 from Vertical Media Concepts on Vimeo.
    Let me know how I can fix this, please!
    Thomas Roell replied 14 years, 7 months ago 5 Members · 4 Replies
  • Angelo Mike
    January 22, 2012 at 2:12 am
    That’s interlacing. So the footage that you’re seeing those lines on has two fields of video for every frame, and they should be blended (or interpolated) into a progressive scan render. Check your render settings and make sure it’s set to progressive scan and that you have a deinterlace method set to either blend or interpolate the two fields.
    Although…I’m not sure how you would deal with it if some of your footage isn’t interlaced. I mean, I don’t know how you should set your project settings, and whether you should set them to interlaced or progressive scan. I’m guessing interlaced.
    http://www.scenethroughglass.com
  • Stephen Mann
    January 22, 2012 at 4:02 am
    You mean this:
    That is interlacing artifacts where the subject moved significantly between the odd and even scans. Yo didn’t say where the AVCHD files came from, but was this clip from that camera?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Steve Rhoden
    January 22, 2012 at 10:06 am
    The way how to fix that is to Deinterlace the footage,
    Because what you are seeing is interlacing.
    I use Borisfx Deinterlacing filter anytime i come across clips
    like this.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Thomas Roell
    January 22, 2012 at 12:33 pm
    I’d say the first thing you should do is to turn off resampling. The next thing you should do is to change the deinterlacing from “blend” to “interpolate”. Since you are downconverting to progressive anyway (and the GoPro is already progressive) that should take care of this.
