Activity Forums Apple Final Cut Pro Using Automator and AppleScript to automatically change an angle of a multicam clip every n seconds – how?
  • Using Automator and AppleScript to automatically change an angle of a multicam clip every n seconds – how?
    Posted by Artur Babich on February 28, 2018 at 11:46 am
    I have 1 hour long multicam clip (2 cameras, 1 audio) that i’m not going to fully watch but i need to change camera every 15 and 30 seconds (first camera is on for 30 seconds, then second camera is on for 15 seconds – and so on till the end). How can i make a script to do this work automatically?
    Serj Kasparoff replied 8 years, 1 month ago 3 Members · 4 Replies
  • Jeff Kirkland
    March 1, 2018 at 2:16 am
    FCPX isn’t scriptable so I don’t think there’s any way to automate this within FCPX.
    The only thing that comes to mind is that if you grab a keyboard macro app, you might be able to set up some keyboard macros to jump 15 seconds then switch to angle 1 and another to jump 30 seconds then switch to angle 2, then another macro to repeatedly alternate the first two until the end.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Serj Kasparoff
    July 26, 2018 at 11:19 pm
    Artur, tell us, please, how you’ve done it as a result?
  • Artur Babich
    July 27, 2018 at 5:11 am
    I wrote a script using AppleScript in Automator (Service gets no input data in Final Cut Pro).
    on run {input, parameters}
    tell application "System Events"
    tell process "Final Cut Pro"
    delay 3
    key code 123 using {control down, command down}
    repeat 80 times
    delay 1
    keystroke "+"
    set textToType to "30."
    keystroke textToType
    keystroke return
    keystroke "2"
    keystroke "+"
    set textToType to "15."
    keystroke return
    keystroke "1"
    end repeat
    end tell
    end tell
    return input
    end run
    This script simulates my hotkeys: it chooses first cam, then after 30 seconds – second cam, then after 15 seconds – first cam and repeats for 80 times which equals 60 minutes.
    I run service in final cut services and then just wait for it to finish.
  • Serj Kasparoff
    July 27, 2018 at 5:17 pm
    Wow, it’s impressive. Didn’t know FCPX can be scriptable.
    Thanks for your example!
    Can you tell me, is it possible to do a script for a drop-down menu?
    I need to change multicam properties for a thousand clips, but the “Modify” button in the inspector disappears when selecting more than one clip.
