Activity Forums AJA Video Systems Using Audio inputs for voicework
  • Using Audio inputs for voicework
    Posted by Michael Nichols on August 24, 2009 at 7:47 pm
    Just curious. I have a 4 channel, powered mixer. Maybe with Logic or Soundtrack Pro (or even FCP), can I use the line outs from the mixer into the inputs on the breakout cable and capture live Audio through the Kona 3?
    Abel Cine Tech – Rental Coordinator
    We now have Red and SI-2K in our Rental Fleet!
    212.462.0163 • mnichols [at] abelcine [dot] com
    Jeremy Garchow replied 17 years ago 4 Members · 6 Replies
  • Jeremy Garchow
    August 25, 2009 at 12:10 am
    Sure. You’ll want to send a stable video source to it for reference, though. You don’t have to capture video, it doesn’t need anything fancy, just a stable video signal.
  • Michael Nichols
    August 25, 2009 at 12:31 am
    Will bars from a signal generator be sufficient?
  • John Fishback
    August 25, 2009 at 2:03 pm
    Yes.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • James Sullivan
    August 25, 2009 at 8:15 pm
    The KONA 3 is digital only. It does not have analog inputs!!!
    James Sullivan
  • John Fishback
    August 25, 2009 at 8:22 pm
    Wow. Forest <> Trees! Of course, it’s AES audio in only. We feed analog signals to our Kona 3 with the AJA IO or our digital audio console.
    John
  • Jeremy Garchow
    August 25, 2009 at 8:34 pm
    woops, for some reason I saw LHe.
    My mind’s playing tricks on me.
    Jeremy
