Activity Forums Audio using AT897/cnsidering NTG2/3
  • using AT897/cnsidering NTG2/3
    Posted by Jim Stamos on July 19, 2012 at 7:10 am
    just shot my first 35 minute short film using the at897. i was pretty impressed with it for its overall performance. the rode ntg2 is in the same price range and the ntg3 is alittle more. since im still in the 30 day return window, im curious from those that have used these mics, should i stick with what i have or go with one of the other 2? i will mainly be using it for films and docs.
    Bob Kessler replied 14 years, 2 months ago 2 Members · 1 Reply
  • Bob Kessler
    July 21, 2012 at 3:40 pm
    All things considered, the AT897 and NTG2 are very similar. If you recorded exactly the same source at the same time I think that most people would not hear the difference.
    The NTG3 does sound better, even to about half of the “average listeners” out there. The other big difference is that, unlike the AT897 and NTG2 which both can be powered by a battery, the NTG3 can only be powered by external phantom power. So if you are using a budget recorder like the H4n or DR-100 you will go through batteries like crazy; you’ll need fresh batteries about every 90 to 120 minutes. So you will either have to invest in many sleeves of batteries, battery packs, a separate phantom power supply (one more potential problem on the set) or get a new digital audio recorder.
    IMHO you would not really hear an appreciable difference between the AT897 or NTG2 and the NTG3 if you are not using at least a prosumer recorder like the HD-P2, FR2 or PMD-661 with their better quality preamps and AD/DA convertors.
    All of the technical cow dung aside, quality production sound lies heavily on the skills of the boom-op. If you have a good boom-op you will get solid production sound with even a low budget mic like the AT897 or NTG2; if you’re handing the boom to an inexperienced PA or mounting it on the camera it won’t matter how much you spend on the mic.
    Peace,
    Bob
    ____________________________________________________________________
    Filmmaking is the art of the invisible;
    If anyone notices your work you haven’t done your job right.
