Activity Forums Adobe Premiere Pro Using Aspect HD with Conroe CPU
  • David Newman
    September 5, 2006 at 9:40 pm
    It seems that the disk is limiting you to three streams. If each 60i stream averaged 15MB/s (guessing) your drive is unlikely to sustain 60MB/s necessary for four video streams and the audio data, with seeking. A second drive in RAID-0 will fix this.
    David Newman
    CTO, CineForm
    – David Newman
    – CTO, CineForm
    – web: http://www.cineform.com
    – blog: cineform.blogspot.com
  • Payner44
    September 5, 2006 at 11:03 pm
    It appears that way. As mentioned earlier in this string, I am installing a RAID controller this week to set up a RAID 0 using two of the new perpendicular Seagate Barracuda drives (320GB x 2), which should increase realtime performance to acceptable levels. Thanks to everyone for feedback and suggestions. I will post again if further issues arise.
Page 2 of 2
