Activity Forums Compression Techniques Using Apple Compressor to batch process for Video iPod>
  • Using Apple Compressor to batch process for Video iPod>
    Posted by Dan Warvi on November 16, 2005 at 8:19 pm
    Has anyone tried to use Compressor to batch-process QT movies for the Video iPod? QT Pro is slower than Christmas….and we’ll need to encode 200+ hours of News stories and features somehow.
    Another post had mentioned that Apple had posted the “cookbook” for this, but I can’t find it – does anyone have any info on this?
    Dan Warvi
    After Effects, Avid, Motion, Broadcast Systems & PC as nec
    Matt Larson replied 20 years, 8 months ago 4 Members · 3 Replies
  • Charles Simonson
    November 17, 2005 at 12:48 am
    Compressor is very unlikely to offer any performance improvements over QT, because they both use the same engine. But, with Compressor, you can enable grid encoding, which can result in about a 6x performance increase on the proper network and node machines. If batching is all you need, then there is an Automater action available from Apple’s website that can export multiple movies to a particular format.
  • Calvin
    December 7, 2005 at 2:40 am
    I was using the compressor preset ‘web download quicktime 7 compatible, H.264 300K’ thinking I was producing video ipod compatible podcasts. Not so. Check out these links. compressing using the method described in the second link produces videos compatible on the video ipod
    Calvin.
    https://www.capria.tv/2005/11/compressor-2-video-ipod-settings.html
    https://www.capria.tv/2005/10/speeding-up-h264-encoding-for-ipods.html for
  • Matt Larson
    December 13, 2005 at 10:01 pm
    Check out a piece of software called “Podder” ($10) It let’s you do batch lists and you can choose between h.264 or mpeg-4 (MUCH MUCH MUCH faster)The presets are pretty good and it takes a lot of the headache out of tweeking all of the settings in QT Pro
