Activity Forums Adobe Premiere Pro Using animated GIFs in premiere pro CS3
  • Using animated GIFs in premiere pro CS3
    Posted by Simon Nadin on January 28, 2010 at 5:03 pm
    Hello.
    Ive created some simple 2 frame animated GIFs, set to “unlimited loop” in photoshop CS4 for use in a Premiere Pro CS3 project.
    I can import the GIFs to the project window and drag them to the timeline, but when I play the clip I only see the first frame. I wondered if premiere is unable to play the images correctly but the help section states that it is.
    I tried making a GIF with 20 frames (the 2 original frames repeated 10 times each) and this plays ok. Is it possible to use a looping GIF or do I really have to go through the tedium of creating a many framed GIF that doesnt loop, when I only want two frames to alternate over and over?
    Thank you for any help you can give me.
    Cheers, Si.
    Simon Nadin replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
