Activity › Forums › Maxon Cinema 4D › Using an object buffer to apply glow, but then how do I allow glow to still have its edges
  • Using an object buffer to apply glow, but then how do I allow glow to still have its edges
    Posted by Craig Ricker on May 2, 2012 at 11:26 pm
    So basically, I have a phone with buttons. i want the buttons to glow as they are pressed. I can use an object buffer to just affect the buttons. But the glow doesnt look any good without a slight expansion outside of the buttons?
    You know that sorta soft falloff. i.e the radius of the glow. The glow otherwise just looks like i’m changing the color of the button?
    Hope that made sense?
    Brian Jones replied 14 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 3, 2012 at 4:21 am
    buttons that glow from the inside are probably better done with the backlight channel shader (or maybe Chanlum or SSS) check out the glowing lamp thread, unless you really want the glow to be outside the buttons and that’s what the Glow channel or the AR Glow effect does.
