Activity Forums Maxon Cinema 4D Using an object as the light
  • Using an object as the light
    Posted by Yoondo on May 9, 2006 at 2:04 am
    Hi, I wanted to know how I could use an object that I created as the light bulb itself.
    I’d appreciate it if anyone could explain it briefly or direct me to a tutorial.
    Thanks alot.
    Adam Trachtenberg replied 20 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 9, 2006 at 4:54 am
    It’s pretty easy actually. Create a light and set the type to “Area”. Then go to the light’s Details tab and set the “Area Shape” to object/spline. Now drag your object into the object box and check the “show in render” box below that.
  • Yoondo
    May 9, 2006 at 5:23 am
    Thank you so much for your help.
  • Hawkowski
    May 10, 2006 at 6:25 pm
    My 3d object consists of many parts grouped under a null object.
    When I try to drag and drop the null obejct (and so its children) into the “Object” field in the “Details” tab of the area light, the Object field doesn’t accept my object. But the same field accept say a simple Cube object after that object made editable.
    How can I make my multi-part object a light source?
    Thx
  • Adam Trachtenberg
    May 10, 2006 at 7:47 pm
    You’ll have to either connect the parts into a single object or use separate lights for each part.
