Activity Forums Maxon Cinema 4D Using an image sequence in a luminance channel – no global illumination visible.
  • Using an image sequence in a luminance channel – no global illumination visible.
    Posted by Matthew Ingram on July 2, 2021 at 5:55 pm
    Hi there,
    I’m hoping this is possible. Is there a reason a PNG image sequence in a luminance channel does not emit light in a GI calculation? Am I doing something wrong?
    Thank you.
    Matthew Ingram replied 5 years, 2 months ago 2 Members · 4 Replies
  • Justin Thomson
    July 2, 2021 at 6:08 pm
    What are you using for you renderer? Standard c4d?
  • Matthew Ingram
    July 2, 2021 at 6:10 pm
    hi justin, thanks for getting back to me. physical renderer.
    i just did a test on a single object and it seemed to work fine – i just can’t see it very much in my scene.
  • Justin Thomson
    July 2, 2021 at 6:19 pm
    You’ll need to raise the “Generate GI” value under Illumination in the material editor.
  • Matthew Ingram
    July 2, 2021 at 6:23 pm
    thank you yes. at 1000% right now so cranked up pretty high. anyway thanks for getting back to me.
