Activity Forums Adobe Encore DVD Using an Icon as a Highlight
  • Using an Icon as a Highlight
    Posted by Dave Hatch on December 16, 2009 at 2:38 pm
    I have created a motion menu using After Effects CS4 and have imported into Encore CS4 using the Dynamic Link function. Everything is working fine except for the highlight set. I am using an icon of a baseball as my highlight to indicate which button the cursor is selecting. I have followed the proper naming conventions outlined by Adobe; all I see is a solid white dot and no red seems.
    Any suggestions?
    Thx
    Dave Hatch
    Senior Producer
    HUGE iDEAS Video Production
    Dave Hatch replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jeff Bellune
    December 16, 2009 at 3:16 pm
    Per the DVD spec (and not just Encore), a button highlight is a 2-bit, 4-color graphic. You can’t use a normal image as a highlight.
    To get what you want, you need to fool the audience. Set up a series of duplicate menus and use the Auto-activate property of the buttons.
    The first menu would have the baseball graphic showing next to the first button. Link that to whatever asset or chapter is appropriate.
    The next button (as determined by the button routing setup) should link to a second menu that is a duplicate of the first menu. When the audience navigates to the next button using the arrow keys on the DVD player remote control, the auto-activate feature takes them to the duplicate menu, where the baseball is now shown next to the second button. On this menu, the second button now links to whatever asset or chapter is appropriate.
    And so on. Make sure you use a hand-drawn flowchart to help you set up this complicated navigation scheme, or you will easily get lost.
    Caveat: although this technique works on hardware DVD players, it won’t work on software DVD players when the mouse is used to navigate instead of the cursor on the remote control.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Dave Hatch
    December 16, 2009 at 3:45 pm
    Thanks Jeff
    I’ll give this a try
    Cheers
    DH
    Dave Hatch
    Senior Producer
