Activity › Forums › Apple Final Cut Pro Legacy › Using an audio EDL to recover a timeline
  • Using an audio EDL to recover a timeline
    Posted by Michael Lansdell on February 2, 2011 at 11:23 am
    Hi, it’s been awhile since I’ve had to post a question up here, but I’m pulling my hair out and you guys always come through :o)
    I have a bunch of audio only EDLs for a series made by the company I work at back in 2000. Over 5 years before I started, so I have know idea why the only record kept of the series was the edl used for the dub (and the masters)… I now need to do some work on this series, and so I was hoping I could use the edls to help me find the video. I’ve done something like this before where I had a timeline that only had video references on and I went through clip by clip pressing f to match frame and f10 to drop the video back into the sequence with the audio tracks. I can’t seem to work out how to do this the other way around though. Any ideas for how to get video track references that I can then go through and capture?
    Hope that’s clear, any thoughts at all greatly appreciated!
    Michael Lansdell
    Online/Offline Editor
    My system:
    2 x 3 GHz Quad-Core Intel Xeon
    5GB DDR2 RAM
    512MB ATI Radeon X1900 XT
    OS X 10.4.11
    Final Cut Pro 6.0.4
    After Effects CS4
    Blackmagic Design DeckLink HD Extreme (6.6.2)
    Take a gander at my personal blog:
    http://www.monstersareart.co.uk
    Michael Lansdell replied 15 years, 7 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    February 2, 2011 at 12:54 pm
    Maybe go through the EDL in a text editor, and add the video to the list? It’s been a long time since I manipulated an EDL, but seems to me it’s just a matter of adding a V to each edit… right? or something just as easy… 2 v’s? LOL? I just can’t remember exactly but it’s not that hard to do I’ll wager.
    Then import that new EDL and batch capture it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Michael Gissing
    February 3, 2011 at 2:05 am
    The best EDL manipulation software I ever used was Shotlister by Digiteyes, an Australian company. It ran on a Win machine (everything from Win3.1 to the latest and also under WINE in Linux) It converted an EDL into a column based graphica interface. You could copy an audio track to a video track and then create a new EDL which had audio edits mapped to video.
    The company is no more but I know the principal and just a few weeks ago I suggested he post a free version of the software up for just this sort of thing. An alternative would be to contact me directly and I could run your EDLs through and map the video track to make a new EDL.
  • Michael Lansdell
    February 3, 2011 at 11:04 am
    Thanks for your help guys! I actually kept fiddling after posting this, and remembered that you can turn off “use clip settings” when capturing, so I used that to pull in all the clip data and then went through pressing ‘f’ and then ‘f10’.
    Michael Lansdell
    My system:
    5GB DDR2 RAM
    OS X 10.4.11
    Final Cut Pro 6.0.4
    After Effects CS4
