Activity Forums Adobe After Effects Using an anchor point is a good idea unless you have to adjust it?
  • Using an anchor point is a good idea unless you have to adjust it?
    Posted by John Hill on June 10, 2015 at 5:53 pm
    I’m animating photos and understand that I should use the anchor point instead of the position tool. But I am scaling out of a photo while changing the anchor point. The move does not happen the way I want and I need to adjust the anchor point. However I understand that one can only adjust the speed of an anchor point. The only option is to attach a camera to the layer?
    Or is there something else I can do? Maybe using position is not so bad after all?
    John Hill replied 11 years, 2 months ago 53,024 Members · 1 Reply
  • John Hill
    June 10, 2015 at 8:44 pm
    Thanks, Dave! You’re right. After setting some anchor key frames and working with the speed graph I was able to do it! Appreciate your guidance.
