Activity › Forums › Adobe After Effects Expressions › Using an adjustement layer to control other layers’ movement
  • Using an adjustement layer to control other layers’ movement
    Posted by Alfonso Gamez jordano on July 22, 2008 at 7:34 pm
    Hi.
    My question is simple. Is there a way to affect layers movement using an adjustement layer above, the same way it affects them when using effects?
    I’m trying to do a small “physics system”, where the adjustement layer will be the “gravity controller”, and all layers below would fall, that way, using an expression to rule them all 😛
    PS: I know I can achieve this by parenting every layer to a null object, for example, and controlling nulls position, but I would like to do it “cleanerly” by using the adj layer.
    Alfonso Gamez jordano replied 18 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 22, 2008 at 8:32 pm
    Try applying the Transform effect to the adjustment layer and see if that gives you what you’re after.
    Dan
  • Alfonso Gamez jordano
    July 23, 2008 at 3:51 pm
    Thanks, that was it!
    I didn’t even know such “effect” existed xD
    Thanks again
