Activity › Forums › Adobe After Effects › Using After Effects and Premiere together
  • Using After Effects and Premiere together
    Posted by Beatcow on July 22, 2007 at 9:18 pm
    Hello hello there.
    I love the way that AE and premiere pro work interact with each other using the Dynamic Link function, however the relationship seems a bit one sided. I like how you can make an AE composition and have it dynamically updated in premiere, but can you go the other way around? What I mean is that let’s say I have a movie edited in premiere. I now want to add some effects to it, so I load it up in after effects. Then let’s say I want to add some footage or do some more editing in premiere. Is there a way that I can open it up in premiere and that the changes I do in there are dynamically updated in AE? I would like to know the best way of using both of these programs “in sync”. I hope I made myself clear, and hopefully someone can shed some light on my question.
    Beatcow replied 19 years, 2 months ago 3 Members · 4 Replies
  • Steve Roberts
    July 23, 2007 at 1:17 pm
    Have you upgraded to CS3? The relationship between the two apps is closer, apparently.
    Try Googling “after effects” + premiere + “dynamic link”.
    Here’s one of the links I found in that search:
    https://kb.adobe.com/selfservice/viewContent.do?externalId=332431&sliceId=1
  • Beatcow
    July 24, 2007 at 1:17 am
    Ok I finally found out that Dynamic Link only goes one way. So I came to the conclusion that I’m going to import Premiere footage into after effects, and then export as a project when im done. Sounded like a good plan until I imported my project into after effects, and all hell broke loose. All the footage in my sequence is all over the place, only 1 cross dissolve is still functioning, and everything is in dissaray. Am I doing something wrong or is there something I should know about? I’m simply importing my Premiere 2.0 project in AE…
  • Bart Straman
    July 24, 2007 at 9:05 am
    here we go again again (a simple search and you will find this answer in like 10 posts, but okey)
    heey,
    i think this will help you :
    -Edit your clip in Premiere. than save your project.
    -open After Effects. file>import, then import your Premiere Pro project file.
    -now you see your clips in the project panel and very important a sequence file (it’s called that way I thought).
    -double click on that sequence file (important: do not move it into the timeline, just double click). and all your seperate scenes/shots/files (cut in Premiere pro) appear in the timeline in AE as seperated layers (also transitions and styles from Premiere PRo are imported).
    -then use coole effects on them separedly. if you wanne render in AE, your done here.
    render out in Premiere :
    -then save your AE file. and if you wanna render it out in Premiere pro, just open the AE project file in Premiere.
    -then only 1 clip will appear, but you’ve edit this the first time in PP and allready applied effects on it in AE, so no prob there 🙂
    i tried dynamic link, but this is only a options for 1 scene/dvd menu or whatever per sequence. only usefull if you wanne see direct result between AE and PP. not with a movie with 200 shots or so:P
    Greetzz
    Bart
  • Beatcow
    July 24, 2007 at 7:14 pm
    Thanks for your help guys!
