Activity Forums Adobe After Effects Using AE to animate B&W drawing (shaking effect)
  • Using AE to animate B&W drawing (shaking effect)
    Posted by Lance Gambis on October 4, 2011 at 12:40 pm
    How would I animate a drawing to just get that every so slight effect of shaking to imbue a black and white line drawing some life.
    Like in this video: https://vimeo.com/24884553
    thanks!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Kevin Camp replied 14 years, 11 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 4, 2011 at 2:43 pm
    in your example, they used several drawings of the same image to create the effect (maybe around 3-5).
    you could try something similar using photoshop to trace a few more still drawings by hand, depending on the complexity, it might not take too long. then just compile several drawings in to a short clip and loop it.
    another way to get wiggly lines in ae would be to try an effect like turbulent displace or roughen edges and animating the evolutions property then adding the posterize time effect to make it a bit more jerky.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
