Activity Forums Compression Techniques Using Adobe Media encoder can i output to a single file not video and audio that needs to be transcoded in Encore? Also any encoders that utalize all of the cpu?
  • Using Adobe Media encoder can i output to a single file not video and audio that needs to be transcoded in Encore? Also any encoders that utalize all of the cpu?
    Posted by Squashky on June 10, 2006 at 3:39 pm
    basically as said above can Adobe media encoder output a single file not 2 files video and audio?? i looked but i fould no settings i could change for that
    Also are there any encoder that aren’t to expense that could utalize a dual core cpu encoding at 100%. The Media encoder i have built in PP use 56% of the CPU(p4 3.4) when encoding filtered video……
    thanks for the help.
    Squashky replied 20 years, 2 months ago 1 Member · 1 Reply
  • Squashky
    June 11, 2006 at 3:13 pm
    hey i tryed the demo for procoder but when i try to use it in primere it just says PP has had a problem that has to close and it shuts off. but procoder’s windows stays up but it estimates it will take 798 hours.
    any ideas on first post or this one?
