Activity Forums Adobe Premiere Pro Using adjustment layers to add spice to Premiere’s bland transitions
  • Using adjustment layers to add spice to Premiere’s bland transitions
    Posted by Derek Andonian on May 17, 2012 at 8:40 am
    One of the big criticisms of Premiere Pro from the FCP switchers has been the lack of good transitions. This is a criticism I wholeheartedly agree with- but with CS6 I’ve found a remedy, which I think will be good to use to give transitions pizazz and originality even after the built-in variety gets improved.
    What I did is start with a 6-frame cross dissolve, then put a 12-frame adjustment layer directly over it. I then added a gaussian blur to the adjustment layer, and keyframed it to start at 0 then go to 200 right over the cut, then back to 0 at the end. The end result was a “blur dissolve”.
    I then played around with it a bit, and had it also became high in contrast in the middle, and a couple other things, and really liked the results I got.
    The effects that are applied to the adjustment layer can be saved as presets, and you can also set the duration of an adjustment layer in the project panel by right-clicking on it, so you could create one just for putting over transitions, then apply a preset to it.
    There are a few more steps involved in this, but I thought it opened up a lot of possibilities. Having the entire arsenal of PPro’s effects available to liven up transitons is pretty cool.
    (Now, if only you could use adjustment layers to change the SCALE of clips below them- then you could re-create that cool “cross zoom” transition from FCP…)
    ______________________________________________
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
    Nevin Styre replied 14 years, 3 months ago 6 Members · 6 Replies
  • Alex Udell
    May 17, 2012 at 9:13 am
    Hey Greg…
    nice tip…way to think outside the box.
    go to the effects panel.
    search “transform” (found under distort)
    can you add this to an adjustment layer?
    https://help.adobe.com/en_US/premierepro/cs/using/WS1E7C690B-2342-43c3-9253-2BAAFF4168EF.html#WS455D57FC-0BB8-4ff2-B629-9AC78419A1C6a
    Also PPro lets you save a combination stack of effects applied to a clip as preset.
    https://help.adobe.com/en_US/premierepro/cs/using/WS40C519D9-F6AF-431f-B36E-C143208921A0.html
    Optionally when you save, you can save it with Keyframes set to scale.
    this means if you make and adjustment layer segment with a different duration from your original elsewhere on the timeline….then apply the preset, the keyframes should be applied proportionally based on the different duration.
    (it doesn’t mean they will scale proportionally if you trim the clip…if you need to trim the clip duration, remove the effects and reapply the preset)
    let’s see what you can come up with now….I’m very interested….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Derek Andonian
    May 17, 2012 at 10:30 am
    Alex Udell go to the effects panel.
    Yes, it does! Cool!
    fully re-creating “cross zoom” from FCP would probably require a lot of effort to pull off, but it’s nice to know transform works on adjustment layers.
    Alex Udell Optionally when you save, you can save it with Keyframes set to scale.
    Saaaweeet!! I was just thinking it would be nice if you were able to do this with presets. This will be a real timesaver.
    I tried a few other effects, and noticed that Turbulant Displace also makes a nice transition effect…
  • Mike Molenda
    May 17, 2012 at 2:16 pm
    I’ve been keyframing my own “flash frame” transitions (mimicking the excellent Too Much Too Soon plugin for FCP) for a while now.
    Adjustment layers will be a huge timesaver for things this, and open the door for custom DIY transitions. And you can set the ease in/out! Definitely not as elegant as drag-n-drop transitions, but a neat tip nonetheless. Thanks!
  • Paul Neumann
    May 17, 2012 at 2:42 pm
    Like so many Adobe products it pays to think like Photoshop to get the most out of what you’re working with. Stacking adjustment layers, multiple instances of effects at different degrees, multiple blend modes, etc. On the surface it looks like an editor but underneath there’s so much you can do. You always heard After Effects as “Photoshop on steroids” and if you take that same thinking into your PPro environment a whole bunch of things open up for you.
  • Gus Evangelista
    May 18, 2012 at 2:23 am
    Adjustment Layers: one of the reasons I was excited about PPro CS6! AE and Ps have had it and now it finally comes to PPro.
    I also made a FlashFrame transition preset for an adjustment layer but recently discovered the free ‘drag-n-drop’ flash-transition along with other transitions at filmimpact.net
  • Nevin Styre
    May 18, 2012 at 5:35 pm
    Adjustment layers are so powerful in AE I’m glad they brought them to premiere. Really though doing photoshop work I wonder why they don’t make the photoshop adjustment layers more like AE, right now you can do individual image control/colour correction adjustment layers but it would be great if they gave us blank adjustment layers we could add stackable filters to like in AE. That way I could add an adjustment layer then throw a darkening curve and a blur filter, then mask out the center to make a custom vignette… like I do in AE today.
