Activity Forums DVD Authoring Using AC3 1st time – Can’t author in DVDSP
  • Using AC3 1st time – Can’t author in DVDSP
    Posted by Dorit Grunberger on April 24, 2007 at 4:51 pm
    Hi to all
    Taking everyones advice, I switched from AIFF to AC3 for compression of FCP project soundtrack through Apple Compressor. I changed the presets to -31db and pre-processing to “none” instead of the default. The compression was successful. I then imported assets (m2v and AC3) in to DVDSP and tried to burn a 1st play DVD (on DVD-R, pioneer internal DVD burner, G5 pre-intel/universal) and got the following messages:
    Build cancelled
    Formatting finished.
    Building was not successful. See log.
    The formatting job was canceled by the user.
    Starting DVD Build UNTITLED_DISC…
    Compiler Initializing…
    Precompiling Project UNTITLED_DISC
    Language codes for ‘English’ and ‘English-2’ must differ
    Build cancelled
    I have NO CLUE what this all means or why it happened.
    Anyone out there know???
    Thanks in advance, Dorit
    Dorit Grunberger replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
