Activity Forums Adobe After Effects Using a video as texture in Elements 3d
  • Using a video as texture in Elements 3d
    Posted by Luis Garcia on May 8, 2018 at 8:35 am
    Hi! I have a question… I would like to use a video as a texture in elements 3d. When I have tried it with a cube created into elements 3d, I can use it without any problem, but whenI have tried it into a imported polygon (imported from hexagon 2.5 wit .obj extension) the texture doesn´t appear into the face of this new polygon, like in the case of the cube. The texture turn into a smooth brown but I can´t see the video into it.
    I would like to do that… Please, help.
    Thanks in advance!
    Cheers
    Mark Whitney replied 8 years, 3 months ago 2 Members · 1 Reply
  • Mark Whitney
    May 8, 2018 at 4:01 pm
    Sounds like a UV mapping issue with your new poly. You’ll have to dig down into E3D and look at what it’s defaulted too for that geometry. Should be a quick & easy tweek.
