Activity › Forums › Maxon Cinema 4D › Using a video as a background for reference
Posted by Elad Menashe on July 28, 2007 at 7:15 pmHello,
I want to use a video background as a reference for adding some elements in 3D world.
It’s been an hour since I tried doing this and still no luck.Anyone has solutions?
greatly appreciated 🙂
EladBrian Jones replied 14 years, 4 months ago 3 Members · 4 Replies -
Brian Jones
July 28, 2007 at 11:03 pmFor background of the Left, Right, Top windows choose Edit(Edit of the view window not the main program edit menu)/Configure then click the Back tab and add your movie there. It will animate automatically.
Otherwise use a background object or a plane and put your movie in a material (color or luminance channel) and put the material on the BG Object/Plane. To get it to animate as you scrub the timeline you have to go into the Illumination tab of the material and check off Animate Preview.
Chris Wood
April 11, 2012 at 1:06 amHi Brian, I tried that, and it’s not working.
Perhaps it’s because I have only imported frame 1 of my JPEG image sequence, but I can’t work out how to import more frames.
Brian Jones
April 11, 2012 at 1:42 amI don’t think you can use an image sequence in the Viewport/Back tab it’s not like a material where you can click on the image and get more settings (the Bitmap Shader/Animation tab) and enter (or Calculate) the number of frames. I think you’d either have to use a movie or use a Background object where you could use the image sequence in a material (but it would only be visible in some form of a render that way though).
