Activity Forums Adobe Audition Using a USB mic with Audition 2.00
  • Using a USB mic with Audition 2.00
    Posted by Tonyor on November 10, 2007 at 8:18 pm
    Hi, I have just bought a Samson USB Studio Condenser Microphone but Adobe Audition 2.00 cannot see it. I get the following message when I try to access it:
    “The selected input port or ASIO driver is invalid. Please change your settings in the audio hardware setup dialogue”.
    However, most of the time the Audio Hardware Setup option is grayed out and when I can get into it, the default input drop down list is also grayed out with the word “None” in it.
    This is really odd because all of my other recording software can see the mic with no problems, including Windows Sound Recorder.
    By the Way, I’ve got Windows Vista Home Premium edition.
    A friend suggested I should download Asio4all and I did but it made no difference.
    Anybody got any ideas?
    Many thanks,
    Tony
    John Ferguson replied 18 years, 7 months ago 5 Members · 5 Replies
  • Willie Toth
    November 11, 2007 at 12:30 am
    First thing you should know is that 2.0 sucks really bad and it wasn’t written to work on a vista operating system although there are some that have had minimal luck using vista … I don’t have 2.0 on any of my computers but in 1.5 on the SESSION side go to OPTIONS > DEVICE PROPERTIES
    Across the top there should be a tab that says REWIRE click on the tab and then click on ENABLE, it should show your mic … For further help go to HELP > CONTENTS then to REWIRE WORKING WITH Hope this solves your problem …. WILLIE
  • Tonyor
    November 11, 2007 at 10:40 am
    Hey Willie, thanks for your advice there. I should have mentioned that we do also have 1.5 and that the mic works fine with it and all other Windows based audio software. It’s just AA 2.00 that we have problems with.
    I’ve a feeling that the answer is, as you suggest, that 2.00 is not designed to work with Vista or USB mics. However, if anyone else knows of some other silly little mistake I’ve made that could be causing this, please let me know.
    Many thanks,
    Tony
  • Emmett Andrews
    November 12, 2007 at 8:35 pm
    Try downloading ASIO4ALL. It typically helps with ASIO related problems found in 2.0. However, Vista may very well be the issue.
    Emmett
  • Kumar Kumar
    January 17, 2008 at 8:41 pm
    I think I know the answer to your problem. I also faced the same problem and solved it myself.
    Goto
    Edit -> Audio Hardware Setup.
    Now under the “Edit View” tab you will see the button “Control Panel…”
    Click on that button.
    In the next window you will see two groups
    1)DirectSound Ouput Ports
    2)DirectSound Input Ports
    Under DirectSound Input Ports whatever is present, you will see that it is not selected. Select it (a cross mark appears) and then click OK and OK.
    Thats it! Everything should be fine 🙂
    Enjoy…
  • John Ferguson
    January 19, 2008 at 3:19 am
    Hello. Did the suggestion above help?
    Contact me if not 🙂
