Activity › Forums › Adobe Premiere Pro › using a TV as output window
Posted by David Payne on January 2, 2010 at 7:08 pmhi all,
I have a graphics card with 2 DVI outs and I want to use a 23″ LCD TV as my output window for premiere. Is there an option to set premiere up to output to the TV specifically or do I just set up an extended desktop and drag it across?
is this generally recommended or would I see a low quality image on the tv?
David Payne replied 16 years, 7 months ago 3 Members · 6 Replies -
Vince Becquiot
January 2, 2010 at 10:36 pmYes, you would set up your card’s second output as extended desktop, then tell Premiere to output to that screen in the playback settings. That will give you a full screen playback automatically.
It is not however the best way to monitor quality since the signal is usually “cleaned up” by the graphics card before it gets to the TV.
Therefore, you may not catch things such as banding, noise etc.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Brian Louis
January 3, 2010 at 1:18 amWhat version of Ppro are you using, what inputs do you have on the monitor? whats the native resolution? what resolution do you want to preview?
Some monitors have a db15 input(VGA), you can use a adapter, some have HDMI you can use a DVI to HDMI cable, if you have Ppro CS4 you can preview to an external computer monitor or TV setup as one or use somthing like a Blackmagic intensity to view previews on a external via hdmi while having two computer monitors for other tasks -
David Payne
January 5, 2010 at 11:26 pmThanks to you both. Brian I’m going to have to start offering you payment for all of your replies!
I’m using premiere pro cs4 and have not purchased the monitor yet. I intend it to be a 26″ hd tv with hdmi so I can use it as a tv too.
I think my max monitor Res is 1600×900 but could be wrong. Should I avoid tv’s then and use a dedicated 2nd monitor for playback if the quality is better? -
David Payne
January 5, 2010 at 11:31 pmAlso, if it’s any help what I’m more keen on spotting are black frames, camera jumps, stutters et. As opposed to noise.
I often spot mistakes when watching a DVD back that I didn’t spot in the small pc window
Brian Louis
January 8, 2010 at 7:32 pmUsing in computer overlay is ok for composition and general layout and workflow preview, but to do stuff like color correcting and matching you need to use a external video display, using a video output like a BlackMagic intensity or a Matrox MX02mini and a tv monitor that can take a decent calibration, and has full resolution, you can get 1080P in 22″ and up.
David Payne
January 10, 2010 at 9:00 amThanks again brian I’d really like to get at least 1080i on a 22″.
I’ve read up on both of those devices and am still not 100% clear on what they are!! Are they not capture devices? I take it they do more than just capture? Do you know where I can get a written beginners introduction to these devices for a total newbie? I thought it would just be a case of using the 2nd graphics card output but it seems it’s not that simple?Many thanks
