Activity Forums Adobe After Effects Using a stroke reveal as a track point
  • Using a stroke reveal as a track point
    Posted by Dylan Hargreaves on May 12, 2011 at 12:24 pm
    Hey CoW people,
    I’m working on a little logo animation using mask stroke effects to reveal the text and the ‘lozenge’ shape around it.
    It’d be kind of cool to apply a sparky particle effect to the lozenge shape as it’s revealed and the way to do this has me a bit stumped.
    I tried pickwhipping the position of the particles to the ‘end’ value of the stroke effect, but this only moves it from the start position to the end without following the line. So how do I get the mask/stroke path data into Particular?
    Thanks in advance!
    Dylan Hargreaves replied 15 years, 4 months ago 2 Members · 2 Replies
  • Jeremy Minton
    May 12, 2011 at 9:24 pm
    I believe Dave’s solution might be quicker…
    Alternatively, you could also use a light emitter in particular and copy the mask path from your stroke layer to the position of the light.
  • Dylan Hargreaves
    May 12, 2011 at 10:04 pm
    Thanks guys. Will give your solutions a go. Found a workaround which was to copy the mask path to the position of a null, although for reasons I can’t work out the copied path was significantly offset from the original.
    Not too much trauma to reposition it, and doubtless a fairly simple explanation, but odd nonetheless.
