Activity Forums Boris FX Using a separate file as Alpha
  • Using a separate file as Alpha
    Posted by Chad Tate on October 26, 2005 at 4:26 pm
    Ok, I have tried alot of stuff, and cannot get this to work. I want to use a quicktime movie as the alpha channel for another quicktime movie. Sounds easy enough, but I cannot find how to do it with Boris Red. I can do it very easy in AE, but can’t for the life of me figure out how in Boris Red.
    Chad Tate replied 20 years, 11 months ago 2 Members · 3 Replies
  • Chad Tate
    October 26, 2005 at 4:57 pm
    Found my answer. I was trying to put a video clip in a luma key effect, but you have to do it backwards. Drag the Alpha Clip to the Mask of the desired Clip. Apply Luma Key effect to Alpha Clip, adjust clipping to you liking.
  • Mark
    October 26, 2005 at 6:34 pm
    Chad, you got it, except, try using the make alpha key filter instead of the luminance key….that is what it is made for.
    HTH
    Mark
  • Chad Tate
    October 26, 2005 at 7:47 pm
    Thanks a ton! I knew there had to be something. I knew Boris wouldn’t miss something like that, but they sure did make it hard to find.
