Activity Forums Adobe After Effects Expressions Using a script to add an expression to a layer?
  • Using a script to add an expression to a layer?
    Posted by John Wilkins on March 30, 2008 at 11:41 am
    I’m not sure if I’m approaching this from the right angle but I’d appreciate some feedback.
    Dan has just helped me with an expression: timeToCurrentFormat(time) which when applied to a text layer’s source property displays the frame numbers of the comp as a timecode.
    I want to include this function in a script I’ve been working on which stamps the filename, framerate, aspect ratio etc. as new text layers to a selected comp (like a slate).
    Is it possible to script an new text layer which has timeToCurrentFormat(time) as the expression for the source text property? or are scripts-scripts and expressions-expression with the two never meeting?
    Thanks for any advice you can offer
    John
    Yaavi Foxy replied 8 years ago 8 Members · 13 Replies
  • 13 Replies
  • Filip Vandueren
    March 30, 2008 at 6:32 pm
    Hi John,
    there’s no problem in setting an expression from a script, you can for example use this in a script:
    app.project.activeItem.layer(1).text.sourceText.expression = “timeToCurrentFormat(time)”;
  • John Wilkins
    March 30, 2008 at 6:51 pm
    Thanks Filip, thats a great help!
    One quick query though, could you advise me how I could re-phrase the script to create a new layer rather than replace the (1) layer.
    Thanks for your help, I really appreciate it.
    John
  • Filip Vandueren
    March 30, 2008 at 8:10 pm
    OK,
    I’m no scripting expert but I think something like this should work:
    activeComp=app.project.activeItem;
    T=activeComp.layers.addText();
    T.name = "Timecode Burn";
    T.startTime = 0;
    T.outPoint = activeComp.duration;
    T.text.sourceText.expression = "timeToCurrentFormat(time)";
    T.transform.position.setValue([100,80,0]);
    Please note that you can’t set the style of the text via scripts or expressions (the Font, size, kerning, colour, etc.)
    It will use the current settings, so first make a textlayer using the style you want, delete it and then you can run the script.
  • John Wilkins
    March 30, 2008 at 9:02 pm
    Thanks great Filip – just what I needed. Thanks again!
    John
  • Ted Mihu
    June 30, 2014 at 1:55 pm
    Hello, I was wondering how I can add an expression to an Audio Amplitude null through scripting. I want to add a smooth expression to the “Both Channels” slider effect of the null.
  • Xavier Gomez
    July 1, 2014 at 1:00 pm
    app.project.activeItem.layer(1).effect("Both Channels")(1).expression = "smooth(0.2, 5, time);";
    See this: https://forums.creativecow.net/readpost/2/911517 to see how smooth works.
    Xavier
  • Ted Mihu
    July 3, 2014 at 2:11 pm
    Thank you so much!!
    Any chance you know how to access the anchor point of a layer in script? I can’t find any help online, and since it’s two words, I’m having trouble.
  • Dan Ebberts
    July 3, 2014 at 4:15 pm
    Try this:
    app.project.activeItem.layer(1).property(“Anchor Point”).setValue([0,0])
    Dan
  • Dave Jackson
    June 29, 2016 at 7:34 am
    I know this is years later and its annoying to keep adding to an old thread but it’s along the same lines:
    How would you target a selected property to add the expression to, in order to make it more versatile?
    this works:
    app.project.activeItem.layer(1).property(“Position”).expression = “wiggle(2,2)”;
    but this would be more useful, and doesn’t:
    app.project.activeItem.selectedLayers.property.expression = “wiggle(2,2)”;
    cheers
  • Dan Ebberts
    June 29, 2016 at 4:32 pm
    I guess I’d do something like this:
    props = app.project.activeItem.selectedProperties;
    for (var i = 0; i < props.length; i++){
    if (props[i].canSetExpression){
    props[i].expression = "wiggle(2,2)";
    Dan
