Activity Forums Adobe After Effects Using a Pre-Comp as particle in Particular
  • Using a Pre-Comp as particle in Particular
    Posted by Moog Gravett on June 1, 2014 at 10:34 am
    Hi Folks,
    I’m trying to make a transition which has lots of random squares which magnify portions of the screen.
    I tried to do this by setting up a 200×200 pre comp which has an adjustment layer with the magnify plugin on it.
    The adjustment layer works fine, but when I hook it up as a sprite, or textured poly in Particular, there’s no magnification.
    Also tried to Pre-comp, just in case.. but no.
    Anyone got any clues as to how I might get this working?
    Cheers,
    Moog
    Michael Szalapski replied 12 years, 2 months ago 2 Members · 2 Replies
  • Michael Szalapski
    June 2, 2014 at 6:06 pm
    You might create a precomp with some particles in it that have a gradient inside them and use that precomp to drive a Displacement Map effect.
    Alternatively, you could use Card Dance to do something similar (but in a completely different way).
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Moog Gravett
    June 3, 2014 at 8:34 am
    Ahhh, yes – I was thinking about a gradient approach, but I couldn’t remember where I’d see something like that before.
    I was in a bit of a hurry, I ended up hand animating a few squares with a magnify filter on them, then heavily distorting and pixelating the rest of the background.
    Appreciate the help though 🙂
    Moog
