Activity Forums Apple Final Cut Pro Legacy using a photoshop matte in FCP
  • using a photoshop matte in FCP
    Posted by Andy Nitchman on May 16, 2006 at 3:13 am
    Okay I need to matte out all but a jigsaw puzzle piece shaped part of a video clip. Then I need to bring that video clip into a motion and key out everything but the video inside the puzzle piece.
    What I tried was a two step process. First I made a puzzle piece shaped matte in photoshop. Then I place the puzzle shaped matte over my video clip so ever thing but the puzzle shaped center was black… I exported my FCP sequence as a quicktime file… then imported the quicktime file into motion and keyed out the black…
    Now the only problem with this process (apart not really being a two step process like I said) is that I’m having a really difficult time keying out all the black without loosing part of my vidoe… I don’t want to use green because there is a lot of green in my video… I tried using pink but that worked even worse then black…
    So what I want to know is… what is a better way of doing this… can I export a quicktime file with an imbeded alpha channel? if so, how do i do that? Also will converting my photoshop file to “NTSC colors” help
    -AnDy (FCP 5 n00b)
    2.0GHz Dual-core G5
    2 GB RAM
    NVIDIA GF 6600 256
    Tom Meegan replied 20 years, 3 months ago 2 Members · 1 Reply
  • Tom Meegan
    May 16, 2006 at 12:21 pm
    Import your puzzle piece and your video clip into Motion.
    Place the Puzzle piece on top the video in a composition.
    Select the Puzzle Piece in the Layers tab of Motion.
    Then select Object > Blend Mode > Stencil Luma.
    This assumes the puzzle piece itself is white and the background is black.
    Tom
