Activity Forums Adobe After Effects Using a Null Object to pass over an object?
  • Using a Null Object to pass over an object?
    Posted by Brandon Pines on March 14, 2013 at 7:27 pm
    I am not sure if I am asking this correctly but I will give it a try.
    I have a project that has several layers. To simplify my question I will says I have a foreground Video (a person), an image behind the video that sits on another image (a frame of sorts).
    I am trying to produce the effect where the camera zooms past the video of the person and brings the two graphics into full frame. I thought i needed to do this with a null object but had not had success.
    I also want to see how I can link the two graphics together so I can apply the camera effect on both of them.
    I hope someone here can assist me.
    Brandon Pines replied 13 years, 6 months ago 3 Members · 4 Replies
  • Brandon Pines
    March 14, 2013 at 10:08 pm
    Thank you Dave. I was hoping you would answer!
    I understand pairing the camera to the null, but how to i target the images in the background to have the camera fly past the video in the foreground and make the two images behind (which I assume I would parent one to the other) to fill the frame?
  • Darby Edelen
    March 14, 2013 at 11:34 pm
    If you are animating the camera then you don’t need a null.
    If you are animating the objects then you could either:
    1) Animate one of the layers and parent the other two layers to it.
    2) Animate a null and parent all 3 layers to it.
    In general I would pre-compose the frame layer with its content, then you only have 2 layers to deal with.
    Alternatively you could parent the frame layer to the layer it’s framing (or vice versa). In that case you don’t need to parent the child layer to the null since the parent layer would already be parented to the null.
    Darby Edelen
  • Vishesh Arora
    March 15, 2013 at 11:30 pm
    Brandon
    There is no way other than animating the Camera(parented to a null or not).
    You have to do it manually. As Dave said creating a Camera Rig would help to give precise and subtle camera moves.
    Check this tutorial:
    https://lesterbanks.com/2010/05/after-effects-using-simple-camera-rig-and-sure-target-together/
    Or you can use Video Copilot’s Sure Target Plugin which will automatically animates the camera and move to the next target. Though you have to experiment with it a little.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Brandon Pines
    March 19, 2013 at 4:00 pm
    Dave,
    I am not trying to turn the camera around an object in 3D space. I am trying to have the camera “fly” passed the video in the foreground and make the smaller images on the layers behind the video (and to the upper-left) be pulled into the camera view and centered on the screen.
    So Video of person is on my right and images on the upper left. I want to have the camera go past the video and bring the images into full frame. That is the effect I am trying to achieve.
