Activity Forums Apple Motion Using a motion tracker to adjust a layer’s anchor point
  • Using a motion tracker to adjust a layer’s anchor point
    Posted by Ken Nemetchek on January 12, 2008 at 9:22 pm
    Hello all!
    I’ve got an animation with a zoom. I am going from a very small area and pulling out to see the entire shot, but I want to scale one of the layers in the shot while the entire image is scaling (hope that made sense).
    I used Analyze Motion to track a specific point on the base layer, and now I want to apply that data to the anchor point of the layer that I want to “grow” over the course of the shot.
    Is this possible? I couldn’t find anything in the manuals about applying tracking data to parameters other than the three basic ones, but I though I should check.
    Thanks in advance!
    Ken
    Ken Nemetchek replied 18 years, 7 months ago 2 Members · 2 Replies
  • Doyle Rockwell
    January 13, 2008 at 5:49 am
    Howdy,
    You can use the ‘Track’ parameter behavior. Just right-click on the Anchor Point parm name and select ‘Track’ from the menu. The behavior will put a single tracker onscreen and will apply it to the target parameter.
    If you’ve already got a good track done in your Analyze Motion behavior, though, there’s no need to re-track. Just click on the little gear-icon menu in the Inspector for the Track behavior and it will allow you to select the already-existing Analyze Motion, grabbing the data from the other behavior. All tracking-related behaviors can share data with one another.
    Good luck on your project!
  • Ken Nemetchek
    January 14, 2008 at 6:03 pm
    Excellent info.
    Thanks very much!
    Ken
