Activity › Forums › Adobe After Effects Expressions › Using a marker with specific name to trigger animation multiple times
  • Using a marker with specific name to trigger animation multiple times
    Posted by Andrew Millen on March 14, 2019 at 2:03 am
    I’ve got two markers on a shape layer each called “Click.” I use this expression to animate the scale:
    rampStart = marker.key("Click").time;
    rampEnd = marker.key("Click").time + .15;
    startVal = [100,100];
    maxVal = [85,85];
    rampMid = rampStart + (rampEnd - rampStart)/2;
    if (time < rampStart || time > rampEnd){
    value
    }else if (time < rampMid){
    ease(time,rampStart,rampMid,startVal, maxVal)
    }else{
    ease(time,rampMid,rampEnd,maxVal,startVal)
    Using the code found here, I want to replace the “wobble” effect with my own scale expression above AND have it specify the marker by name, not just any marker on the layer.
    n = 0;
    t = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) n--;
    if (n > 0) t = time - marker.key(n).time;
    amp = 15;
    freq = 5;
    decay = 3.0;
    angle = freq * 2 * Math.PI * t;
    scaleFact = (100 + amp * Math.sin(angle) / Math.exp(decay * t)) / 100;
    [value[0] * scaleFact, value[1] / scaleFact];
    But I’m not conversant enough in expressions to make it happen. Can anyone help? I’m sure it’s super obvious to someone who knows what they’re doing.
    Andrew Millen replied 7 years, 6 months ago 2 Members · 2 Replies
  • Oleg Pirogov
    March 14, 2019 at 4:38 am
    I suppose you only need to add a line that checks, if the comment of nearest (from the left) marker equals “Click”:
    theMarker = marker.key("Click");
    if (n!== 0 && marker.key(n).comment == "Click") theMarker=marker.key(n);
    rampStart = theMarker.time;
    rampEnd = theMarker.time + .15;
    maxVal = [85,85];
    value
    }else{
    P.S. I’ve omitted marker.numKeys > 0 condition since your code assumes there’s at least one marker anyway.
    And if there are several markers with the same comment (a.k.a key(name)) “Click”, this: marker.key(“Click”) – returns the first of them
  • Andrew Millen
    March 15, 2019 at 2:21 am
    That did it, thanks!
