Activity › Forums › Field Production › Using a MacBook Pro as a monitor for Canon XF300
  • Using a MacBook Pro as a monitor for Canon XF300
    Posted by Josh Smith on April 12, 2013 at 1:32 pm
    I used to have a Canon XH-A1, with which I used the FireWire output into my MacBook Pro, and used Adobe OnLocation as a field monitoring solution.
    This worked absolutely fine for me… until I upgraded my camera to the XF300. The XF300 doesn’t have a FireWire output, only HDMI and Component etc. Adobe OnLocation only supports FireWire input, not HDMI.
    Now I’m stuck – I can no longer use my MacBook on location shoots as a monitor!
    Can anyone recommend any alternative monitoring software that allows HDMI signal input? Adobe have discontinued OnLocation, so there’s no hope of there being an update to improve compatibility.
    I know that there is a piece of hardware that converts the HDMI signal from the camera into an HDV signal ready for FireWire that is compatible with OnLocation (https://bit.ly/cua9f0) – but it’s nearly £600 GBP, and I’m not spending that much money on a simple converter!
    I just want a piece of monitoring software that I can use on my MacBook that is compatible with the HDMI signal from my XF300.
    Any help is appreciated!
    Angelo Lorenzo replied 13 years, 5 months ago 2 Members · 1 Reply
