Using A Layer Position to Control a specific range value?
Ive been trying to see if I can figure this out for a couple days, so I wanted to see if anyone can help me here…
This is what im trying to achieve. I have a source text (with a slider in its effects that controls its value) and a layer/graphic that needs to move up and down. I need the slider value to be parented to the y axis of the layer’s position. However, when I do that im obviously getting numbers in the hundreds to thousands when I slide the layer up and down.
My goal is to still have the value parent to the y axis, but instead of giving me the same value as that axis, I need it to be a specific range instead of following the positions value. By default when the layer is at the bottom of the comp, I need the value at zero, but when you slide the layer to the top, it goes all the way up to 25 but stops there.
Obviously if I take the “current” number in the position value and subtract that in the value of the slider, it will get me at zero. But because the position value is sensitive to large numbers, im not sure how to tell the slider to be more relative to that number so I can slide the position all the way up, and have the value make its way to 25 instead of 2000?
Hopefully that made sense… Any help would be awesome!
