Activity Forums Apple Final Cut Pro Legacy Using a gradient in FCP problem
  • Using a gradient in FCP problem
    Posted by Don B. cely on January 28, 2007 at 8:52 pm
    Greetings!
    I have a gradient created in Photoshop I’d like to use as a background for a graphics sequence. However, the gradient ends up looking “dithered” or you might say it has banding rather than being smooth.
    Can anyone suggest a solution to this problem?
    Many thanks!
    Don in Atlanta
    Treadwell replied 19 years, 6 months ago 5 Members · 5 Replies
  • Bret Williams
    January 29, 2007 at 3:30 am
    Add some minor noise in ps or don’t use the DV codec. You can try adding a little blur.
  • Chuck Reti
    January 29, 2007 at 5:30 am
    It is called quantizing error. Comes with the Digital Video territory. Has since the beginning. It’s not a bug, it’s a feature.
  • Rafael Amador
    January 29, 2007 at 1:35 pm
    What Bret says it works. Also you can create a 16bits gradient in PS and render in a 10b uncompressed time-line. Never DV.
    Cheers
    rafael
  • Don B. cely
    February 7, 2007 at 10:06 pm
    I appreciate everyone’s response!
    Rafalaos’ suggestion of a 16 bit grad and rendering in a 10b uncompressed timeline sounds very interesting, I will try it!
    Thanks to all!
    Don
  • Treadwell
    March 27, 2007 at 5:46 pm
    I’m having the same problem but I’m not in the DV realm. I’m working in 10bit uncompressed!
