Activity › Forums › Adobe After Effects Expressions › Using a expression to change a paragraph alignment.
  • Using a expression to change a paragraph alignment.
    Posted by Lucas Malaquias on March 30, 2020 at 7:44 pm
    Hey, guys!
    Recently, I’ve been exploring the new possibilities for text expressions in After Effects 2020. I am currently using this expression to change my font based on a value.
    var array=[
    “font-01”,
    “font-02”,
    “font-3”
    style.setFont(array[0])
    My problem is. My second font (font-02) is supposed to be an Arabic font. Which should be aligned to the right instead of left like in most other languages like English, spanish etc.
    So, is there anyway that I can achieve that with the new tools in AE2020? How can I modify this expression to make sure that the second font is always aligned to the right. And fonts 01 and 03 always aligned to the left?
    var array=[
    "font-01",
    "font-02",
    "font-3"
    Tomas Bumbulevičius replied 6 years, 6 months ago 2 Members · 1 Reply
  • Tomas Bumbulevičius
    April 4, 2020 at 9:19 am
    Hey Lucas, the question here also relies on actual positioning of your text layer.
    Think about this – if you change alignment of a text to right, how and where it must be placed in your design / composition?
    Ideally, you should better define two text layers – one for left alignment languages, other – right. And then switch their opacity based on font selection choice.
    Find out more:
    Motion Graphics Design & After Effects Tutorials
    On YT
    On VH
