Activity Forums Apple Final Cut Pro Legacy Using a edl from a Intel mack same version
  • Using a edl from a Intel mack same version
    Posted by Edward G downie on October 14, 2006 at 2:18 pm
    I have final cut pro 5 on a g4 silver door 1.45ghz OS10.39 with FCP5 I get a job from a client who uses a Labtop with the intel prosser I am unable to open the FCP file it says ‘need newer version of fcp, do I need to upgrade to OS10.4 and upgrade fcp to 5.1 or the universal version or upgrade the computer thanks.
    Jeremy Garchow replied 19 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Uli Plank
    October 14, 2006 at 2:24 pm
    You need to uprade only the program: project files (these are no EDLs) from version 5.1 are not compatible with older versions.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Jerry Hofmann
    October 14, 2006 at 2:31 pm
    You need to upgrade the OS and upgrade to the universal version of FCP.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Edward G downie
    October 14, 2006 at 2:34 pm
    I mean the project file. Do I need to upgrade to OS10.4 in order to get fcp 5.1 as auto upgrade is not seeing it when I click on it
  • Edward G downie
    October 14, 2006 at 2:36 pm
    I wil do that thanks
  • Uli Plank
    October 14, 2006 at 2:54 pm
    You need to buy the upgrade to 5.1, it’s not free or automatic, only the update to 5.1.2 will be free.
    But I suppose you’ll need the newer OS anyway, I don’t think it works with 10.3.
    Regards,
    Uli
  • Edward G downie
    October 14, 2006 at 4:27 pm
    I have FCP 5.04, so I need to purchase 5.1 universal upgrade via the turn in program and that will work.
  • Jeremy Garchow
    October 14, 2006 at 6:53 pm
    You should upgrade, but you can export an XML in the meantime.
    Jeremy
