Activity Forums VEGAS Pro using a dual monitor system in sony vegas with only one monitor connection
  • using a dual monitor system in sony vegas with only one monitor connection
    Posted by Mark Baron on September 19, 2010 at 6:59 pm
    I’d like to use another monitor(dual monitor system) when editing in Sony Vegas 7 running on XP. My computer has only one monitor output. I do have a monitor that uses a USB port. Can I use a USB connected monitor and then connect the other monitor to the VGA connection. It has USB 2
    The HP media center also has a coaxial cable out on the back. Would I be able to attach that to a TV to get an image of my timeline playback?
    Thanks.
    John Rofrano replied 15 years, 12 months ago 2 Members · 4 Replies
  • John Rofrano
    September 19, 2010 at 11:12 pm
    Vegas will use any monitor that behaves as a Windows Secondary Display. The question you need to ask is will the USB monitor look like a secondary display to Windows. No one here can answer that.
    If all else fails, video cards with two outputs can be bought for as little as $24.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mark Baron
    September 20, 2010 at 3:17 pm
    Thanks for you help. Does this graphics card support dual monitor
    NVIDIA GeForce 6150 LE IGP
    can I just add an adapter that will let me connect two monitors?
  • Mark Baron
    September 20, 2010 at 4:23 pm
    Thanks John, you have been very helpful.
    https://h10025.https://www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=ae&docname=c00760067 this is the PC I want to run the dual monitor system on. Only one port out. The graphics card supports dual monitoring, but only if there are two ports. A splitter won’t work.
    Someone suggested Vegas supports a firewire connection to use another monitor. I thought the firewire was in. Anyway, I have other computers with dual monitor capabilites. I’m just wary of using my “Music Computer” to also do video. That would be ideal, but the DAW has way too many programs and I want to keep that for only recording audio. Do you see any whay there could be a conflict between using Samplitude(audio program) and Sony vegas on the same computer. I have enough trouble keeping the DAW running smoothly without throwing other possible conflicts into the mix.
  • John Rofrano
    September 21, 2010 at 2:41 am
    I appreciate your concern of putting other software on your DAW. If it’s not that stable to begin with, I wouldn’t tempt fate.
    Just buy another graphics card for the other PC. You could use firewire but you’d need a firewire converter or you would have to use your camera to pass the signal through. Replacing the graphics card is the cheapest and easiest solution.
    ~jr
