Activity › Forums › Adobe After Effects › Using a depthmap as mask
  • Using a depthmap as mask
    Posted by Mirko Ruta on November 9, 2018 at 7:26 pm
    Hello,
    With a 3D plugin (Trapcode MIR) I created a low.poly landscape. Now I would like to add a glow-effect but not evenly applied to a complete adjustment layer. It should be controlled by a depth-map. The depthmap itself has pixelvalues between black and white so that elements which are more in front are more white and elements in the back are more black. Now I would like to do something like this.
    Add an adjustment layer with glow and use the depthmap as mask (black = more transparent). Is this possible?
    Thanks a lot (and sorry for my bad English)
    Greetings from Germany ☺
    M.
    Walter Soyka replied 7 years, 10 months ago 3 Members · 2 Replies
  • Cassius Marques
    November 9, 2018 at 8:07 pm
    Can’t you use the depth matte as a luma matte for that adjustment layer?
    Cassius Marques
    http://www.zapfilmes.com
  • Walter Soyka
    November 9, 2018 at 8:09 pm
    Sure, that’s possible. You can use the depth map as a track matte [link] on your adjustment layer.
    Alternately, you could use a Compound Blur effect with the depth map and an Add or Screen blend mode.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
