Activity Forums Maxon Cinema 4D Using a Daz 3d rigged character in cinema 4D
  • Using a Daz 3d rigged character in cinema 4D
    Posted by Andrew Wagstaff on July 28, 2025 at 6:29 pm
    I have a human character that has been imported to cinema with a full skeleton from Daz3d and was wodnering if its possible to import animations to the rigg the same way you can do if you rigg a character using the character builder in cinema?
    only reason i havent just used the charatcer builder myself is i always mess it up and thought having a pre made one would be easyier
    Andrew Wagstaff replied 1 year, 1 month ago 2 Members · 4 Replies
  • Kouraib Abdmalek
    July 29, 2025 at 10:42 am
    Hi Andrew,
    If you mean importing the character with animation from DAZ, I don’t think that’s possible even with the paid plugins available on the internet its developers are talking only about providing transfer of rigged characters, including their geometry, textures.
  • Andrew Wagstaff
    July 29, 2025 at 11:33 am
    sorry i didnt explain myself very well
    when you make a charcter using the character rigging in cinema you can generate a walk cycle and import mocap animations if i used a prerigged charcter form daz using the daz to cinema 4d plugin could i use the preset aniamtion on that rig or would i need to re rigg it using the character builder
    only reaosn im using daz to rigg it is ive never been able to do it properly myself i can do most things but not the hands they have always defeated me
  • Kouraib Abdmalek
    July 30, 2025 at 10:25 am
    Thanks Andrew for the clarification, It’s hard to say if this will work without any problems, especially if you’re someone who cares about fine details or if your project requires close observation of movements with the camera zoomed in. However, you may have to give it a try to see for yourself.
    I hope this helps.
  • Andrew Wagstaff
    July 30, 2025 at 8:54 pm
    At the moment i just want the basics, the character is going to be wearing a helmet all the time i just want to have somthing usuable in animations so i can get used to aniamting a humanoid
