Activity Forums Square Box CatDV Using a constant value in calculated field
  • Using a constant value in calculated field
    Posted by Samuel Brosset on October 9, 2020 at 1:03 pm
    How can I use a constant value in a calculated field in JS ?
    It’s now possible to record a constant with Server Settings / Advanced / custom.MyConstantValue
    When I assign a field to a JS variable, I can do
    var MyVariable = ($(“clip[MySet.MyField]”)) ;
    How can I assign in JS custom.MyConstantValue to MyVariable ?
    I tested a lot of syntax without success
    It is possible or not ?
    Thank’s in advance
    Samuel Brosset replied 5 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
