Activity Forums Adobe Premiere Pro Using a camera for a mic?
  • Using a camera for a mic?
    Posted by Richard Evans on May 11, 2006 at 11:35 pm
    I need to record a voice over for a project I am working on, but do not have a mic. Is it possible to use the mic on my camera to record into PP2 for a voiceover? My camera is a Sony HVR-Z1U. Thanks for the help.
    Xavier De champs replied 20 years, 4 months ago 4 Members · 6 Replies
  • Steven L. gotz
    May 12, 2006 at 3:07 am
    Sure. It works fine for most things. Just be far enough away from the PC fans when you record.
    If you need to see the footage, burn it to a DVD and watch it on a TV with the sound muted. A nice quiet room – especially a full clothes closet, works best.
    Steven
    https://www.stevengotz.com
  • Richard Evans
    May 12, 2006 at 9:01 am
    Is it possible to record the audio straight to the timeline, or would i have to record it to tape and then capture it into premiere? The latter is how i ended up accomplishing the task, but i was looking for an easier, faster way of getting this done. Obviously a mic would be my easiest, but i’m not sure where to start when it comes to buying a mic. Any suggestions there?
    Richard
  • Steven L. gotz
    May 12, 2006 at 4:06 pm
    I am very happy with the setup I bought at the Guitar Center.
    I picked up a little preamp, the brand is TUBEPre and the model TP1. It has drive and gain controls and a VU meter. It allows balanced inputs and phono inputs. It plugs neatly into my Audigy2 sound card line jack.
    The Mic I bought is the MXL 2001 from MXL, a division of Marshall Electronics. It is Cardioid with balanced output to my preamp.
    I find it quite easy to work with. Add a nice stand and a pop screen and you are all set for under $150.
    I write out a DVD without sound, and I have a rather long cord, so I can stand in a room away from the PC fans and watch it on the DVD as I record direct to the timeline to a PC in the other room. I have to set it up and then walk over to the mic, but it is easy enough to deal with a few seconds at the beginning and the end. Notice I said stand, and not sit. You will sound better in most cases.
    Steven
  • Skye Sweeney
    May 14, 2006 at 1:46 pm
    My solution was to purchase the Edirol UA-25 mic preamp with phantom power and a USB interface. I also purchased two Behringer B-5 mics. Makes a great portable recording studio.
    -Skye Sweeney
    FLL Freak Productions
    https://www.fll-freak.com
  • Richard Evans
    May 14, 2006 at 1:52 pm
    I’ll be sure to look into some of these options. Thanks for all the help guys.
    Richard
  • Xavier De champs
    May 15, 2006 at 10:11 pm
    I have placed my computer in another room (drilled a hole in the wall). Bought a M-Audio Firewire 410 audiocard. It is a firewire box which connects vie a 10 m firewire cable, and the box is situated in the suite itself. So I have volumecontrol and amp control at my fingertips plus 2 headphone outputs, and of course 8 speaker outputs (only use 2 for stereo, but can buy more audiomonitors and setup for surround, i think). The mic is connected through this great box, and I record in the editing room standing up. The mic is a very good mic, have had lots of compliments from people who have borrowed it. Its a R
