Activity Forums Adobe After Effects Expressions Using a 0-100 slider to keyframe from one position to another
  • Using a 0-100 slider to keyframe from one position to another
    Posted by Arvin Bautista on September 25, 2021 at 9:19 pm
    I’m doing a lot of comps where a map starts out from some wide point (which we’ll call point A) and zooms into a different point (we’ll call point B). The spatial animation from point A to point B is a straight line, but the timing needs to be keyframed as it’s not a simple linear or ease timing.
    I’d love to be able to input the x,y coordinates of Point A and Point B using 2 Point Selectors, and then use a slider control to keyframe the timing of going from Point A to Point B, from 0 (Point A’s position) to 100 (Point B’s position).
    Is this possible?
    (As a side note, I was also thinking of something like this if I wanted to manually control the “strength” of a parent’s influence on its child, where 100 means the child follows the parent’s position perfectly, 0 means it doesn’t follow it at all, and 50 means it only follows at 50% strength)
    Dan Gehin replied 4 years, 10 months ago 2 Members · 2 Replies
  • Arvin Bautista
    September 25, 2021 at 10:29 pm
    I figured it out:
    Two Point Controllers: Point A (x,y) and Point B (x,y)
    One Slider Control from 0-100
    Camera null with separate dimensions.
    On x position:
    var ax = effect(“Point A”)(“Point”)[0]
    var bx = effect(“Point B”)(“Point”)[0]
    ax-((ax-bx)*effect(“Slider Control”)(“Slider”)/100)
    On y position:
    var ay = effect(“Point A”)(“Point”)[1]
    var by = effect(“Point B”)(“Point”)[1]
    ay-((ay-by)*effect(“Slider Control”)(“Slider”)/100)
    Keyframing slider from 0-100 tweens the camera null from Point A to Point B, even if Point A and Point B move also.
  • Dan Gehin
    November 16, 2021 at 9:35 pm
    Instead of dividing the sliders by 100, I would suggest multiplying them by .01 like so:
    …effect(“Slider Control”)(“Slider”)*.01
    This will accomplish the same thing but won’t break if the slider is set to 0 (because its impossible to divide by zero).
