Activity Forums Adobe After Effects Using 3D camera tracker 2D source
  • Using 3D camera tracker 2D source
    Posted by Assaf Tshuva on June 7, 2017 at 6:41 am
    Hey,
    I tracked a footage using the 3D camera tracker (CS6), but the data points weren’t good.
    When I changed “show tracked points” to 2D source it added more points and I found all the tracking points I needed.
    But it seems that those points aren’t usable, the only available option is to delete them.
    I just need a regular 2 points tracking (on a footage that it’s tough to track with motion tracking, that’s why I used the camera tracker).
    So what can I do to use those points? And if they’re not really used for tracking – what is the 2D source’s purpose?
    Thank you.
    Edit: Figured it out. Thanks anyway.
    Kalleheikki Kannisto replied 7 years, 4 months ago 4 Members · 3 Replies
