Activity › Forums › Apple Final Cut Pro Legacy › using 30″ apple cinema
Posted by Greg Ball on November 26, 2006 at 12:33 amIs anybody using ONE 30″ Apple Cinema for FCP? I just set up a system, but it looks pretty crammed with the one monitor. Any suggestions? Should I buy an additional 20″ monitor for bins? What do you do?
Matt Galuszewski replied 19 years, 10 months ago 4 Members · 10 Replies -
Ernie Santella
November 26, 2006 at 12:56 amWhat resolution do have your 30″ set at? I use my 30″ set at 2560×1600 and it works for me. I was using 2 x 20″ CRT’s before and this is much cleaner and faster. You could always hook-up another monitor for more real estate.
Ernie Santella
Santella Film/Video Productions
http://www.santellaproductions.com -
Peter Wiggins
November 26, 2006 at 1:20 amI’d been using 2 23″ Cinemas for nearly 4 years until I started using a 30″
It is a different way of working but you can get the viewer windows running at 100%
size when anamorphic. I thought I wouldn’t like it, but it grows on you.Going back to 23’s makes them look small, but an LCD infont of the client to point to
clips in bins is pretty handy.If you are doing Photoshop, Dreamweaver or any other combination of those type of apps
the 30 is way the best.I’m off to find another fence
Peter
Greg Ball
November 26, 2006 at 3:10 pmMy screen display only gives resolutions up to 1200 X 800. That’s the highest option. How do i get it to 2560×1600? That sounds like the perfect fix.
Greg
Matt Galuszewski
November 26, 2006 at 7:16 pmHi,
Are you using a Graphics card that supports the resolution for the 30″ display – dual link?
If you are, maybe it has 2 connectors and only one of them is dual link.
That is all I can think of.
Greg Ball
November 27, 2006 at 2:54 amI’ve got a GE force 6600. It came with the Mac G5 Quad. Will this not work?
Matt Galuszewski
November 27, 2006 at 7:38 pmI am not familiar with the card but the apple website says…
NVIDIA GeForce 6600 graphics is ideal for Power Mac G5 Dual and Power Mac G5 Quad users who want to view more than two displays at the same time. It provides excellent all-around performance for a wide range of 2D and 3D applications from office productivity, to graphic design, even for games and some professional applications. The NVIDIA GeForce 6600 includes 256MB of GDDR SDRAM and offers both a single-link DVI port and a dual-link DVI port that can simultaneously support one 23-inch and one 30-inch Apple Cinema HD Display.
Based on the PCI Express architecture, the GeForce 6600 fits into any single available slot in your new Power Mac G5. The upgrade kit also includes a DVI to VGA connector for easy connection to VGA-based displays.
Maybe one output is a dual link. Have you swapped the 30″ connector over to the other port and tried the display properties again?
Greg Ball
November 27, 2006 at 9:37 pmSo if i read that right. It should work for me right? I’ll try switching ports when I return home. Thanks again
Greg
Greg Ball
Greg
Greg Ball
November 28, 2006 at 4:24 pmMatt, you were correct, the cinema display was connected to the wrong input. Thanks so much for your help!
Greg
