Activity › Forums › Apple Final Cut Pro Legacy › Using 16mm footage within FCP
  • Using 16mm footage within FCP
    Posted by Damian Dunne on November 16, 2005 at 11:27 pm
    hey guys,
    I have shot a music video on super 16mm. I have captured all the footage at PAL 10bit uncompressed. Is there anything else I have to be wary about when bring my footage into my comp? Like seeting my frame rate to 24fps?
    Any help would be much appriciated!
    Damian
    be the ball
    Shane Ross replied 20 years, 10 months ago 2 Members · 1 Reply
  • Shane Ross
    November 17, 2005 at 7:58 am
    Why did you capture PAL? Did you telecine to PAL? Are you in a PAL country?
    Then just edit PAL 25fps and you should be fine. If your footage was telecined to PAL tapes, then you capture PAL, then you are editing 25fps all the way.
