Activity Forums Adobe After Effects Using 1080 clips in 4K
  • Using 1080 clips in 4K
    Posted by Eric Jordan on March 21, 2014 at 12:11 am
    Hi all,
    Working on an AE animation at 4K resolution for a client, and they would like to be able to mix in some 1080 clips in order to have access to a wider variety of stock video.
    How would this work, would I convert the 1080 clips up to 4K with a plugin? Or just scale it up?
    4K dimensions are so different from 1080, I’m just not sure how this would work…..
    Thanx all,
    Eric
    Chris Wright replied 12 years, 5 months ago 4 Members · 3 Replies
  • Mark Dizz
    March 21, 2014 at 6:09 am
    The quick answer is that you really don’t have much choice but to scale them up since all they gave you was 1080p. There may be some upscaler technique or software out there somewhere but I don’t even know if it is worth it. Unless this is a private thing being shown on a 4k tv or they have access to 4k broadcast I wouldn’t stress too much about scaling it up.
  • Jim Arco
    March 21, 2014 at 11:21 am
    I’ve had good results using the new detail-preserving upscale, located under the effects > distort menu.
    Jim
  • Chris Wright
    March 25, 2014 at 10:47 pm
    this post might be too late, but consider Infognition’s super-resolution to upscale. It uses ajoining frames to get better quality than you could alone.
