using 1 texture across mulitple objects?
Im a newbie to C4d Im afraid, but what I am trying to do is sim a video wall, using multiple 50cm sq panels not necessarily in a full 4×3 rectangle and with the odd panel missing
xxxxx
xx xxxx
xx xxxxx
xxxxxxxx
for example, what Id like to do is assign a texture that covers all the objects, and each object to only display the bmp that covers it.
If this could be done only on the front face, all the better!
Is there an easy way to do this with tweaking each objects texture individually? A way to merge them together for example, although Id like to be able to move them possibly later!Cheers
Chris
