Activity › Forums › Adobe After Effects › user guide location
  • Pierre Jasmin
    May 14, 2014 at 6:25 pm
    Look for the manual folder in path below
    (example below with CS6, the rest does not change)
    C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore\REFill2
    Pierre
  • Gerry Lindfield
    May 14, 2014 at 7:17 pm
    Thanks for this Pierre,
    I’m on a Mac, do you have the path for that?
    gerry
  • Gerry Lindfield
    May 14, 2014 at 7:31 pm
    I’ve found it. Thanks
  • Pierre Jasmin
    May 14, 2014 at 8:41 pm
    for the others (CS5.5 below is version)
    /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore
