Activity Forums Apple Final Cut Pro Legacy User Error: Jumpy Video Fixes? Final Cut Suggestions
  • User Error: Jumpy Video Fixes? Final Cut Suggestions
    Posted by Noah Mingus on October 2, 2008 at 4:11 am
    What is the best way to fix jerky/jumpy video.
    Project: Customer shot video to cut down on cost. Video is jerky, Need a fix within Final Cut Pro, if possible.
    Noah
    Donal O kane replied 17 years, 11 months ago 2 Members · 1 Reply
  • Donal O kane
    October 2, 2008 at 9:37 am
    do you have fcs 2?
    have you tried smoothcam?
    can have great results … also some very bizarre results. worth a try.
    bake a short section to a self contained quicktime.
    drop the smoothcam filter onto it – this will take several minutes to analyze the clip (thus the reason to test on a short clip as smoothcam analysis the entire source clip.)
    then play around with the settings in the filter to get best results.
    i’ve read that it is recommended to lower the translational and rotational smoothness to lower than the default 2.5 but can’t remember where (i’ve had lots of success with aerials and car shots with 0.5-0.75 on each)
    then final render
