Activity Forums Canon DSLR Cameras User defined picture style won’t apply in video mode
  • User defined picture style won’t apply in video mode
    Posted by Gábor Koszper on August 14, 2014 at 11:41 pm
    Hey there!
    This is my first post here, so I hope I’m doing it right.
    My problem in short: My Canon EOS 550D isn’t applying my customized picture styles in video mode.
    Right now I don’t have the access to quality color correction in post production (I own a Pinnacle Studio 15 Ultimate HD and the limited free version of Hitfilm 2 Express), so I’m trying to use this method:
    1. I shoot a still RAW photohraph of the scene I want to shoot.
    2. I use Picture Style Editor to create a picture style file using the RAW image, which I save with .pf2 extension.
    3. In M mode I register the user defined picture style I just saved.
    4. I switch to video mode and in the menu I choose the proper “user defined picture style” slot and switch to the picture style I just registered.
    5. I go into live view and switch to the proper user defined picture style. I check and see that the name of my picture style appears in the bottom right corner of the live view.
    6. I shoot the video using it.
    Now, the video won’t have the picture style I made. It will have the saturation, contrast, etc. that came with it, but the colors don’t change at all. I checked if I messed up when creating the picture style, so I shot still photographs in M mode, but they were correctly applied to the still images.
    Now anywhere I go on the Internet, it is said that this should work. I also think that it is quite obvious that if the special name of my picture style appears that I came up with when saving my file, that should mean that my picture style is applied.
    So, what am I doing wrong? Should I check some settings? I’m afraid that this is some kind of esoteric error with some setting that I forgot about.
    I just want to fix the colors a bit without buying yet another expensive software. Can anyone help?
    Gábor
    Gábor Koszper replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
